Cant launch CPU miner
Discussion in 'Questions and Help' started by Faker0, May 21, 2014.
  1. Faker0
    Faker0 New Member
    May 21, 2014
    Says it wont connect to 127.0.0.1 on port 9### something.
    Do I need to port forward?...seems like an odd error i figured it would list an external ip?
  2. Propulsion
    Propulsion The buck stops here.
    Feb 26, 2014
    1,008
    467
    Dash Address:
    If your trying to mine solo, you need to add settings to your config file.
    rpcuser=[username]
    rpcpassword=[pass]
    rpcallow=127.0.0.1, localhost
    rpcport=9998
    port=9999
    server=1
    Then to connect you would do /minerd -a X11 -o http://127.0.0.1:9998 -u [username] -p [password]
    Unless you have a massive botnet farm, mining solo with a CPU is not recommended. You should join a pool instead.
  3. Faker0
    Faker0 New Member
    May 21, 2014
    Ah i see i see, thanks.
    Will look at that option!
