6950 not showing up on SGminer but my 7970's are
kingcolex
Okay so I am running a newer version of SGminer and my 7970's are doing fine, I decided to plop a 6950 on there I also had and it is not being recognized by SGMiner only the 7970's are. Any advice or things i need to do?
EDIT: Nevermind I am a scrub, if you're using multiple styles of GPU be sure to plug it in as the main display so windows recognizes it before you use SGMiner!
