https://www2.coinmine.pl/dash/Dear Miners,
Due to the fact that we are almost reaching 50% of network hashrate please consider splitting your hashrate a bit into other pools or use p2pool
Wow, either miners do not give a .... or smth is going onUhm, should we be worried?
Hey Paws, have you tried to mine at http://xpool.ca ? I don't work there, I just thought it was easy pool to be set up. I use both dashminer.com (which uses AMD only though), and X. Let me know if it works for you, the setup is pretty easy, and customer service is good...!I would but mining at 2 different pools I got over 70% stale shares, Ghash and a P2pool, is this why? I'm mining at 11MH/s, I recently tried NiceHash mining Quark at 21MH/s in exchange for BTC which I plan to trade for DASH, I would like to go back to p2pool but I can't figure out why my stales are so high there and fine on Nicehash, my miner is the latest ccminer 1.5.60 with maxwell fork on a GTX 980
In the last couple weeks I watched my payouts go from 0.21 a day to 0.02 and I can't run like that.
Could you please make a red alert announcement on BCT and ask the miners to stop mining there? Thank you.61% noobs because I get twice the payout with the optimized dashminer as proved by the stats here :grin:
http://poolpicker.eu/table?algo=x11
compared to here
https://www2.coinmine.pl/dash/index.php?page=statistics&action=pool
