50 Dark Bounty for Masternode Guide Update
Sapereaude
191
235
203
Offering a 50 Darkcoin Bounty : ) for an update to Tao's brilliant Masternode for dumies guide, to include the the new config file for setting up multiple master nodes from the same wallet and instructions informing them how to withdraw profits without stuffing up the node.
Cheers,
Sapereaude
oblox
1,032
537
No idea on the structure of the masternode config, but to send coins, you'd enable coin control (list mode) and select all the payments vs selected the 1000 coin address blocks.
TaoOfSatoshi
2,767
2,616
Dash Nation
www.dashnation.com
Cheers,
Sapereaude
I would gladly add this to my guide, when it becomes available. Hey, and thanks for the "brilliant" compliment!
As far as mentioning how to use coin control, I will add that by tomorrow. Thanks for the suggestion. EDIT: Done!
Propulsion
The buck stops here.
Feb 26, 2014
1,008
467
masternode.conf format is as follows
192.168.0.1:9999 7qspZZJD3wsPifSzxZGnzo4HhR5Pd9MN2X9kGk4gPZi4LMJSvrE
192.168.0.2:9999 7rDDK21opuSHuu7eV2LdmBAunXWRUhVU3ZVek3frqYisnF4HyJL
Winner.
Reactions: tungfa
tungfa
8,972
6,740
And the Winner is ...>
50 to Flare
Sapereaude
191
235
203
Woot Woot! Thanks Flare, Sent : ). Now I just gotta get it to work : p
Reactions: tungfa
flare
May 18, 2014
2,287
2,406
Germany
Thanks! masternode.conf needs to be placed in the current working directory, so it ignores the datadir parameter at the moment.
"masternode start-many <password>" does return no result at the moment, so you need to look at debug.log to figure out if it worked.
Note: start-many is still in alpha state and may not work as expected. For me it worked on 3 out of 4 nodes.
Sapereaude
191
235
203
Awsome
