0.12.1 update: Error when trying to start Sentinel
KryptoTypek
19
11
Hi, I updated my MN to version 0.12.1. Following this guide: https://dashpay.atlassian.net/wiki/display/DOC/Updating+to+12.1+-+Masternodes
My dashd is running and fully synced. But when I try to run Sentinel, I get this error message:
-342: non-JSON HTTP response with '401 Unauthorized' from server
Cannot connect to dashd. Please ensure dashd is running and the JSONRPC port is open to Sentinel.
How can I fix this?
Reactions: fible1
SirHikmat
93
57
68
Do you use a custom path to dash.conf?
If yes, then add the following line to sentinel/test/test_sentinel.conf:
dash_conf=/path/to/dash.conf
Reactions: stan.distortion
3,639
3,537
Make sure you started daemon AFTER you copied/configured dash.conf - try "dash-cli getinfo" - should get you a similar error.
If that is the case:
- rename dash.conf to smth else "mv ~/.dashcore/dash.conf ~/.dashcore/dash_.conf"
- stop daemon "dash-cli stop"
- rename dash.conf back to it's normal name "mv ~/.dashcore/dash_.conf ~/.dashcore/dash.conf"
- start daemon "dashd"
Wait for it to finish syncing and try to run sentinel again.
KryptoTypek
19
11
I started the deamon after the configuration. The deamon is running correctly and is synchronized. "dash-cli getinfo" works ok.
borkanagar
10
6
Was trying to build a new masternode from scratch and got the following error when trying to setup sentinel:
[Errno -2] Name or service not known
Cannot connect to dashd. Please ensure dashd is running and the JSONRPC port is open to Sentinel.​
@chaeplin suggested me to look for any special characters in the rpcpassword in dash.conf file and voula! I had put many symbols there...
Changed the password by removing special characters and now sentinel is doing fine. Many thanks to @chaeplin for helping me on this issue,
prole
Zombie thread sorry, but i ended up here from searching this error. I accidentally typed "rpcusername=XXXX" instead of "rpcuser=XXXX" in my dash.conf and i was getting this same 401 error from sentinel but querying dash-cli worked fine and other symptoms were the same as above. Hopefully it helps someone who maybe did the same thing and is bashing their head against the keyboard.
